Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › LS-Dyna, Negative volume problem. › Reply To: LS-Dyna, Negative volume problem.
December 20, 2024 at 12:24 pm
Raghav
You might check after setting the following parameters:-
set DTMIN (control termination) to 0.5 and TSSFAC (control timestep) to 0.67.
Which kind of hourglass control are you using?
Raghav
