Ansys Learning Forum Forums Discuss Simulation Fluids How to use E85 (ethanol) fuel in Forte Reply To: How to use E85 (ethanol) fuel in Forte
judy.cooper
Hi Mert:
E 85 fuel is 51 percent to 83 percent ethanol blended with gasoline, so you will need to use a chemistry mechanism that supports both gasoline and ethanol (c2h5oh), and enter this blend. You can do this by creating a fuel_mixture to be used in the spray model as shown below:
