Mike Pettit
In Ansys Release 2024 R1 the Aqwa Workbench editor allows you to view the mesh quality in the graphical window. Once the mesh is generated, use the 'Display Mesh Metric' option to see which panels fail the Aqwa mesh quality checks:
To determine mesh independence, you will need to run the Hydrodynamic Diffraction analysis with different Mesh Element Sizes and compare the results between simulations.
I hope this helps!
Mike
