Ansys Learning Forum Forums Discuss Simulation Fluids Continuing a Calculation on an HPC After Patching A Flow Variable Reply To: Continuing a Calculation on an HPC After Patching A Flow Variable
Vijay Narayan
I think you can refer to the secton on Automatially initialize and modify case in Fluent User guide.
36.18. Automatic Initialization of the Solution and Case Modification
Using this route, you can setup the case for cold flow, include command to patch and then continue the simulation further.
If you already have the cold flow converged, then use the dat file available to initialize and then continue with the patch and further steps.
Kindly please explore these and let me know if it helped.
