Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Ansys Forte: fuel not burning. › Reply To: Ansys Forte: fuel not burning.
December 19, 2024 at 9:56 am
There is an example in Forte tutorial which you can refer for guidance on sector modelling of Diesel engine combustion.
Chapter 2: Simulating a Diesel Engine Using a Sector Mesh
Also what is the current sector angle you are considering (how many nozzle holes are there in the injector). Since the simulation with full geometry is working - I'm assuming your chemistry file and chemistry setup should be correct.
What is the pressure and temp rise during the compression stroke and are the fuel getting vaporized completely ? These would help in figuring out the issue on why the combustion is not happening.
