Ansys Learning Forum Forums Discuss Simulation LS Dyna Location of results when using python or cmd to call ls-run to calculate k files Reply To: Location of results when using python or cmd to call ls-run to calculate k files
rji229
Many thanks for your reply. Another problem occurs when I try to use the command to run k files. For example, in the screenshot, I generate a series of k files through code and run these k files through a complete restart (while inputting the corresponding d3dump files). The problem now is that in some steps, the information in the message file has not been updated for a long time, but the Python code is still displayed as being executed. This situation does not happen every time, and may only occur in certain cases. I want to ask if this is the case, how can I determine whether ls-dyna is still iterating the time step or has stopped running?
