Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Thermal analysis using convection surface APDL21 › Reply To: Thermal analysis using convection surface APDL21
MAPDL takes a negative value of convection coefficient (HF) to be HF is a function of temperature based on the MP command defining HF. In this case it is possible for the HF expression to return negative values; not sure if you meant that or not. In any case that element has a negative HF applied so it is looking for a temperature dependent HF defined via MP. To change the behavior use SCOPT which has a option to force the use of a negative HF. See the public help on the command for its options: https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v242/en/ans_cmd/Hlp_C_SCOPT.html
