Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Cross-coupled stiffness elements in LS-DYNA › Reply To: Cross-coupled stiffness elements in LS-DYNA
December 18, 2024 at 5:29 pm
Hello Simon,
I found the following in our knowledge database:
Superelements are not appropriate for bodies undergoing finite rotations. For that case, one could employ flexible rigid bodies (*part_modes)"
One developer told me: "We are working on extending it to large rotations, underway."
And here is more information from our knowledge database:
"A "flexible rigid body" saves cpu time by approximating response using mode superposition. The basic procedure is to first compute normal modes (*control_implicit_eigenvalue) and/or constraint or attachment modes (*control_implicit_modes) of a deformable body. Then in a subsequent explicit analysis, you approximate that deformable body as a "flexible rigid body" via the command *part_modes. Here are links to papers describing the procedure and examples: http://ftp.lstc.com/anonymous/outgoing/jday/Session_12-1.pdf http://ftp.lstc.com/anonymous/outgoing/jday/flexrb.pdf http://ftp.lstc.com/anonymous/outgoing/jday/Bitzenbauer.pdf The first two are essentially the same paper. Example input (rather old, I'm afraid) is in http://ftp.lstc.com/anonymous/outgoing/jday/flexrb_example.tar"
You will find a regular super element example here:
http://ftp.lstc.com/anonymous/outgoing/support/EXAMPLES/superel_inertia_matrix.tar
Let me know if this helps or not.
Reno.
