Ansys Learning Forum Forums Discuss Simulation LS Dyna Initial Velocity Generation Reply To: Initial Velocity Generation
valerym.m5
the solution step is quite small:
dt 1.72E-07
in addition, if there was an impact/contact with bodies lying below the load, then a wave pattern would be visible in the parts where the material has viscous properties.
