Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Thermal analysis problem › Reply To: Thermal analysis problem
Hi,Â
I need help. I am running simulations in Ansys Fluent to determine the heat dissipasion capacity and behaviour of a baterry thermal management system, the heat is never transfered among the parts (cooling plate, cover, fluid).Â
I have created Named selections (channels's faces, fluids' faces, colling plate faces, cells contact area with the cover, cover contact areas with the cells and cooling plate).Â
I have set BC and the cell zone conditions, materials, heat generation rate for the cells and during/after simulation the contours show no heat transfer through the components.Â
I have tried tried w/wo the tool Share in Spaceclaim, adding and deleting Named selections, etc. but nothing works. I don't know what I am doing wrong.Â
Could you have a look and tell me what I am doing wrong?
