Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Target Field Data for Turbulence Model Optimization › Reply To: Target Field Data for Turbulence Model Optimization
December 18, 2024 at 2:17 pm
Murari Iyengar
Hi, you have to disable the node values in the contour plot. Else, there will be interpolation for display which can give you a different range.
