Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › artificial stresses at the fixed points in thermo-structural analysis › Reply To: artificial stresses at the fixed points in thermo-structural analysis
December 18, 2024 at 2:06 pm
You shouldn't need a large value for the elastic foundation stiffness, but it only provides a constraint perpendicular to the surface. You still need lateral constraints. That's probably why you got the error about internal solution magnitude limit exceeded.
