Ansys Learning Forum Forums Discuss Simulation LS Dyna Location of results when using python or cmd to call ls-run to calculate k files Reply To: Location of results when using python or cmd to call ls-run to calculate k files
Reno Genest
You can use the timeout= option with the subprocess.run() method. I tested it and it seems to work.
I Googled "How to set a maximum running time with subprocess.run() Python?" to find the solution.
You can set a maximum running time (timeout) for subprocess.run() using the timeout parameter:
Python
import subprocesstry:    result = subprocess.run(        ["command", "arg1", "arg2"],        timeout=5,  # Timeout in seconds        capture_output=True,        text=True    )    print("Output:", result.stdout)except subprocess.TimeoutExpired:    print("Command timed out")
Explanation:
  • timeout: The timeout parameter takes a float value representing the maximum number of seconds you want the process to run.
  • capture_output=True: This captures the standard output and standard error of the subprocess, making them available in result.stdout and result.stderr.
  • text=True: This decodes the output as text (if possible).
If the subprocess exceeds the timeout:
A subprocess.TimeoutExpired exception will be raised and The subprocess will be terminated."
https://docs.python.org/3/library/subprocess.html#subprocess.TimeoutExpired
Let me know how it goes.
Reno.
