Ansys Learning Forum Forums Discuss Simulation General Mechanical Convergence of Composite Tensile Test Using ACP Reply To: Convergence of Composite Tensile Test Using ACP
zmvick
The output file does note that stress stiffening is on. My displacement vs reaction force graph is very linear all the way through the simulation. (Reaction force is in negative x-direction.)
In the physical specimens, layers did begin to fail right around the 3 mm of displacement. Most had fairly linear force-displacement curves until 3.5 mm or so, and then pretty rapid failure from there. I'm not sure how to change the element type. I am using ACP to model the composite, and ACP only allows the use of surface input geometry. I am then using shell element data in the analysis. I don't know how to use SOLSH190 elements or if it is even possible.
