Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Setup Contacts between multiple .k files › Reply To: Setup Contacts between multiple .k files
Pedram Samadian
Would you please provide more explanation about the model? Why did you use *INCLUDE_AUTO_OFFSET? Does "there is no collison" mean the parts pass each other without any interactions? When you open the main file in LS-PrePost, do you see all the parts in the right place?
Thanks,
Pedram
