Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Issue Wrapping a Spiral (DXF Import) onto a Surface in ANSYS HFSS › Reply To: Issue Wrapping a Spiral (DXF Import) onto a Surface in ANSYS HFSS
Praneeth
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
Please share the steps you have followed for wrapping the object to guide you better.
Kindly go through "Wrap Sheet Command" section of the HFSS help document if you have not gone through it already.
Best regards,
Praneeth.
