Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How can we consider specific modes in modal analysis for expansion in MSUP RV? › Reply To: How can we consider specific modes in modal analysis for expansion in MSUP RV?
December 17, 2024 at 11:40 am
Generally, we use the *GET command to select the modes for further analyses. However, I can see that here you are using MODSELOPTION to select the modes. Maybe you can share the code for the spectrum analysis you are solving.
From the error screenshot you have shared, I can see that solver has started the spectrum analysis. So, the issue might be with commands preceeding the ANTYPE, SPECTR command.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
