Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › #need help. i find its difficult to create model of steel box girder. › Reply To: #need help. i find its difficult to create model of steel box girder.
ashish.khemka
You can try using the command: NUMMRG,KP
If two separate entities have the same location, you can merge these entities together into a single entity via the NUMMRG command. The NUMMRG command does not changes model geometry. Only the topology is affected.
10.1. Number Control
NUMMRG
Ashish Khemka
