Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Issue with Symmetry Conditions in Wet-Running Multi-Disk Clutch Simulation › Reply To: Issue with Symmetry Conditions in Wet-Running Multi-Disk Clutch Simulation
Saeideh.Kermani-Afarani
Thank you for the response. The symmetry plane consists of two parts. One part is in the rotating domain, and the other part is in the stationary domain. Both symmetry surfaces are connected together but are defined separately as two symmetry conditions.
