Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Coarse graining in Rocky › Reply To: Coarse graining in Rocky
Saeed
Thank you for you answer.
1- My question is in coarse graining , ideally, the original size of the particle should be smaller or the size of the particle mutiplied by coarse graining factor should be smaller than CFD cell ?
2- in Rocky particle tab, after adding particles, its pososity can be defined too( the proportion of empty space in a material) .
in density simulation, particles are agglomorating at some parts or moving in a way which does not match the experiments and does not make sense and in porosity simulation, particles are disappearing from the system. But there is no converngence issue.
