Ansys Learning Forum Forums Discuss Simulation LS Dyna Pressure dependency MAT_079 Reply To: Pressure dependency MAT_079
Pedram Samadian
Hi Joerg,
You are welcome. I contacted one of the developers about this and he said "Doing the initial analysis using elastic material is not a good idea as it would not capture the relevant history variable values. Also, recommended practice is to use separate material properties for different layers, and not use B etc."
I hope this addresses your concern.
Thanks,
Pedram
