Ansys Learning Forum Forums Discuss Simulation Electronics How to build different rotor geometry in Ansys Maxwell Reply To: How to build different rotor geometry in Ansys Maxwell
melihstorm1
For example, let’s say I designed a synchronous reluctance motor using RMxprt and then transferred it to Maxwell 3D. After that, I added the rotor cage structure using the user-defined primitive and made the necessary adjustments using Boolean operations. Would it be possible to solve such a design in the simulation?
