Ansys Learning Forum Forums Discuss Simulation Fluids Heat transfer flux vs volume-integral UDF energy source Reply To: Heat transfer flux vs volume-integral UDF energy source
Check the definition of "volume average" in the User's Guide - I suspect you want sum. The other potential issue is that interior faces (surface rather than the interior that's every facet in a volume) don't have a normal assigned so you may find neighbouring cells have + or - values randomly. You may need align the facets to use the reports.Â
