Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › How do I fix this irregular face meshing problem? › Reply To: How do I fix this irregular face meshing problem?
December 14, 2024 at 6:58 am
I am trying to follow this tutorial: ANSYS Fluent: Rocket Engine Nozzle (With Exhaust Plume) - Detailed & Accurate CFD Tutorial.
In the tutorial, they use that kind of geometry, but their meshing actually works first try. I am cutting up the faces of my geometry exactly how they do it, and the only difference is that I am using the different meshing tool than they use. However, I still don't understand why mine does not work at all while their's does. Also the problem only occurs on that area right outside of the edge of the nozzle, the corner.
