Ansys Learning Forum Forums Discuss Simulation General Mechanical nCode Issue with corrupt results Reply To: nCode Issue with corrupt results
danielshaw
The DesignLife system should not show in the Mechanical UI, but if you RMB > Solution inside Mechanical you should see the option to plot external fatigue results.
