Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › nCode Issue with corrupt results › Reply To: nCode Issue with corrupt results
karim.el-ghamrawy
Thank you for the information. I just need to clarify that I am able to add multiple .rst files in ncode. When the run completes, I cannot see the results, or at least the structure misses a lot of components and it looks corrupt.
You mentioned that I can check them using the External DesignLife Fatigue Results. I do not have this in Mechanical. To clarify, when my fatigue is completed in nCode, the module in workbench is not updated as in the following picture
Can you walk me through the steps of finding the External DesignLife Fatigue Results? Any advice on why the module is not updated?
Many thanks,
