Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Location of results when using python or cmd to call ls-run to calculate k files › Reply To: Location of results when using python or cmd to call ls-run to calculate k files
December 13, 2024 at 2:46 pm
Thanks for your advice. If I manually use LS-Run, the result d3plot files are in the current .k file directory, there is no problem.
I use Ls-run because I found an online tutorial that said putting the command in "cmd" could run .k files. I don't know how to use LS-DYNA command lines directly in the Python script. Are there any references, instructions, or examples that I can learn from?
