Ansys Learning Forum Forums Discuss Simulation Fluids mixture fraction of coal combustion Reply To: mixture fraction of coal combustion
Ren
From the coal ultimate analysis you can calculate the required O2 in kg for each kg of coal DAF, and then required air if air is the oxidizer. With the known stoichiometric air/fuel ratio (AFR), you can calculate the stoichiometric mixture fraction:
Zst = 1 / ( 1 + AFR)
