Ansys Learning Forum Forums Discuss Simulation Electronics Plot a field magnitude as a function of an Optimetrics swept parameter Reply To: Plot a field magnitude as a function of an Optimetrics swept parameter
pavel.kirienko
Ok I found the solution. You need to define the point of interest not as a marker, but as normal geometry (using the Draw menu). Say we call the point "ORIGIN":
Then define a new output variable via the Results panel, where you can select which field to sample at the selected point:
You can also directly use it in a Fields report:
