Ansys Learning Forum Forums Discuss Simulation LS Dyna Location of results when using python or cmd to call ls-run to calculate k files Reply To: Location of results when using python or cmd to call ls-run to calculate k files
Reno Genest
By default, the results files (d3plot) and other output files (messag, d3hsp, etc.) are written in the working directory where the .k file is located. I think there is something wrong with your Python script.
I would do the process manually without the Python script first. Does it work?
Also, I would simplify your Python script to only run LS-DYNA. Are you able to get the results file in the working directory? Then, add complexities later.
At last, why do you use LS-RUN? Why not use LS-DYNA command lines directly in your Python script? What LS-RUN does is it takes inputs (number of cores, input file location, solver location, etc.) and creates the LS-DYNA command line and sends it to the computer. The command line created by LS-RUN is in the "Preview" field of LS-RUN:
You can run this command line directly in command prompt.
Let me know if this helps or not.
Reno.
