Ansys Learning Forum Forums Installation and Licensing Ansys Products Regarding the mesh accuracy related issues in HFSS and AEDT Icepak electro-therm Reply To: Regarding the mesh accuracy related issues in HFSS and AEDT Icepak electro-therm
576650550
Yes, I found it difficult to keep the scaling factor higher or lower for each object in both unidirectional and bidirectional coupling, but looking at the loss distribution cloud map, it seems that the temperature of the better mapping is sometimes higher, probably because I adjusted the HFSS and icepak to improve the mapping accuracy while also changing the total loss value. In addition, I used the field calculator to integrate the loss power of icepak objects, and the results of some objects could not exactly correspond to the scaling factor. But in theory it's the process you're talking about.
