Ansys Learning Forum Forums Discuss Simulation General Mechanical nCode Issue with corrupt results Reply To: nCode Issue with corrupt results
danielshaw
I understand that you are using a WB integrated DesignLife system and not the Mechanical embedded Add-On.  The External DesignLife Fatigue Results option allows you to plot fatigue results calculated using onne of the WB integrated systems from within Mechanical.  You do not need to use the Add-On to plot DesignLife results within Mechanical.
Yes, you can connect multiple Mechanical systems to one DesignLife system.  Open DesignLife and RMB > Simulation_Input > Properties.  You should see multiple results files.
