Ansys Learning Forum Forums Discuss Simulation Photonics Updating a Lumerical example Reply To: Updating a Lumerical example
sara.bassil
Hi again,
Thank you for your answer, I was actually trying to implement the sweep in the script.
My goal is to run charge and extract the electric field for each value of the gap.
I want to store the value of the electric field for each value of the gap in a matrix and use it outside of the loop to compute the perturbed index.
The issue I am encountering is regarding the electric field :
The matrix E that is generated in the script with these commands :
electro = getresult("CHARGE::monitor","electrostatics");
E = pinch(electro.E);}
is different from the one I see when I go : monitor > electrostatics > E > view data
Is it because the simulation is using unstructured dataset ?
Anyhow, I have some issues understanding to what corresponds the 3rd size of the E matrix  :
?size(E);
result:
23828  11  3
I assume that the first value is the x values ?
The second one corresponds to the voltage applied
And the third one .. I have no idea ?
Thank you again for your assistance!
