Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Heat transfer in Rocky › Reply To: Heat transfer in Rocky
Chris_g
Thank you for the information!
What values do these functions expect?
I've set up some test cases with a single particle. When I pass nondimensionalized 10W (or 100/1000) with add/set_heat_transfer I get 5-20 Watts more when I evaluate Sum:Solid Explicit Heat Transfer Rate*CellVolume and Particle temperature (m*cp*dT)
For add_explicit_heat_transfer_rate I can't seem to get realistic values whether I pass nondimensionalized Joule, Watt or Watt/cell Volume
