Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Global variable › Reply To: Global variable
December 11, 2024 at 5:01 pm
Hello, the properties of the "model" group (and other analysis/structure groups) are not accessible in this way. If you want to use one of the "model" properties to set a property of another simulation object you can do this in the "model" setup script using the "set" or "setnamed" commands, for example:
