Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › HOW TO EXPORT CONTACT PROPERTIES FROM MY ROCKY DEM SIMULATION › Reply To: HOW TO EXPORT CONTACT PROPERTIES FROM MY ROCKY DEM SIMULATION
December 11, 2024 at 2:26 pm
Hello Ayuk,
You might check the PrePost Scripting manual here for more information on each class or method.
The .GetCollectContactsData() will return if the contact collection is enabled or not. (as follows from the manual)
To get properties from Particles and/or Contacts, you might use
.GetGridFunction('property name')
save it in an array and export using python.
best regards,
Lucas
