Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Shell T-joint contact with 6 DOFs and failure needed › Reply To: Shell T-joint contact with 6 DOFs and failure needed
Hello Nanda,
Thanks for the quick reply. The idea is to model the glue joint using the simplest approach that allows the ultimate force/stress for the glue to be set. I can use the appropriate card to make the contact of type tied_shell_edge_to_surface:
*CONTACT_tied_shell_edge_to_surface
$   ssid    msid   sstyp   mstyp   sboxid   mboxid    spr    mpr
     3     4     0     0     0     0     1     1
$    fs     fd     dc     vc    vdc   penchk     bt     dt
     0     0     0     0     0     0     0     0
$    sfs    sfm    sst    mst    sfst    sfmt    fsf    vsf
     0     0     0     0     0     0     0     0
This card works. The contact transmits translational and rotational DOFs for shell structure.
But I have no idea how to set debonding for this contact(. This setting should have the ultimate stress for the glue that is not being modeled directly.
Could you please help me find the right way to set the appropriate settings?
