Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Radiation to Surroundings › Reply To: Radiation to Surroundings
dlooman
It could be a bug, but you made a very big mesh when you set the element size to 1mm.  You may have hit an untrapped limit of your computer.  Are you running on a lap top with limited memory?  Do you have access to normal tech. support?
