Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Analysis validation using actual values in axial fan rans simulation › Reply To: Analysis validation using actual values in axial fan rans simulation
December 10, 2024 at 1:47 pm
If changing the outlet diameter changes the results, and you don't know what size the outlet is how can you compare with experimental data? Sharing the images would also help: my crystal ball is off for repairs.Â
