Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Question Regarding Simulated Voltage in Coupled Field Modal › Reply To: Question Regarding Simulated Voltage in Coupled Field Modal
erik.kostson
Hi
The absolute values of the deformation/voltages (which are huge as you can see) of the modal analysis mode shape results do not mean anything as these are scaled eigenvectors/modes.
Only the frequency and the over all mode shape is of interest but not as said the exact and absolute magnitude. displacement/voltage values.
Hope that is clear. If not see here for some more discussions:
https://innovationspace.ansys.com/forum/forums/topic/natural-frequencies-anslysis/
https://innovationspace.ansys.com/forum/forums/topic/unrealistically-large-deformation-modal-analysis
I would suggest a course from ais on modal analysis where this also explained.
The displacement/stress results and voltages are of interest and can be looked at, once and when applying a force in a coupled field harmonic analysis.
See also our tutorials on this (coupled field harmonic):
In the help manual for the: Mechanical Technology Showcase: Example Problems Chapter 39: Wire Bonding Ultrasonic Transducer
Erik
