Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Analysis validation using actual values in axial fan rans simulation › Reply To: Analysis validation using actual values in axial fan rans simulation
egozukara
I checked pressure and velocity contours, as well as 2D and 3D streamlines. The flow is affected by sudden expansion as the outlet tunnel diameter increases, but I don't know what the tunnel diameter at the outlet will be.
