Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Best way to apply a remote force and displacement to reduce DOFs › Reply To: Best way to apply a remote force and displacement to reduce DOFs
December 10, 2024 at 11:50 am
Hey,
So the direct displacement should work for you.
And regarding the warning you can check the weak spring forces that are being generated. If they are low it won't be a problem.
To check what is causing that error you can check out this course https://innovationspace.ansys.com/courses/courses/prevent-rigid-body-motion-in-contact/
Mohan Urs
