Ansys Learning Forum › Forums › Discuss Simulation › Optics › Assistance Needed for Wavelength Adjustment in Optical Ring Modulator Simulation › Reply To: Assistance Needed for Wavelength Adjustment in Optical Ring Modulator Simulation
Dear Gwang,
I hope this email finds you well. I am currently working on a project involving the modulation of a laser signal using a ring modulator. The objective is to utilize a voltage waveform provided via a PWL (Piece-Wise Linear) file to modulate the laser output.
The specific requirements for this setup are as follows:
- The input voltage waveform, described in the PWL file, should be used as the control signal for the ring modulator.
- The ring modulator should appropriately modulate the laser signal (intensity, phase, or frequency) according to the PWL voltage waveform.
- The output of the system should reflect the modulation pattern dictated by the input voltage.
Additionally, I would be immensely grateful if you could provide a circuit design for this system and share the corresponding ICP file. Having this would significantly aid in the implementation of the project.
I would appreciate any guidance, resources, or suggestions on implementing this setup effectively. Please let me know if there are specific tools, software, or experimental setups that you recommend for simulating or realizing this configuration.
Thank you for your time and assistance. I look forward to your response.
