Ansys Learning Forum › Forums › Discuss Simulation › Photonics › How to determine the position of DFT monitor on farfield scattering analysis ? › Reply To: How to determine the position of DFT monitor on farfield scattering analysis ?
December 9, 2024 at 10:50 pm
Thank you.
Should the position of the monitor be closer to the scatterer when using other sources (plane waves or Gaussian beams) as well?
For example, When I want to put a monitor under the source, should I set the monitor 2-3 cells away from the scatterer?
