Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Unable to set mass-flow outlet while using DDPM › Reply To: Unable to set mass-flow outlet while using DDPM
December 9, 2024 at 5:12 pm
Thank you Rob!
The plan was to use DPM but I am unable to add a discrete phase unless I enable DDPM.
How may I use particles in fume hoods using DPM, if I may ask you, please?
Thank you so much!
