Ansys Learning Forum Forums Discuss Simulation Electronics No currrent for my Maxwell-3D design Reply To: No currrent for my Maxwell-3D design
MirandaH
Thanks for the info, close loop shouldn't have this issue. You can use surface->section to cut coil terminals from the geometry, this will ensure coil terminal perfect nest inside of the coil.
