Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Initialisation, parameter ‘Expression Value’ is defined Single Valued › Reply To: Initialisation, parameter ‘Expression Value’ is defined Single Valued
December 9, 2024 at 1:43 pm
It seems that the expression pout0 has inadvertently connected to qout0prev. I kindly request you to carefully review all the expressions, as this may be a minor issue that can likely be resolved with a thorough check.
