Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Script Error 800a000d in meshing › Reply To: Script Error 800a000d in meshing
Rajeshwari Jadhav
Hi Isaac,
Yes, there is some issue with latest windows 11 update 24H2.
Settings> System> Recovery> Go back, The Go Back method will only work if you downgrade to windows 10 within the 10 days of your upgrade (No Data Loss).
When Go back option is grayed out, you have other options to rollback to windows 10 bit you might need to do some research on it or if this is your academic system then you can contact your IT they will help you (Data will be lost).
May I know which Ansys application you are using, if we have any alternate we can share it?
For Aqwa follow this JavaScript Runtime Error in AQWA Pre on Windows 11 (Version 24H2)
