Ansys Learning Forum Forums Discuss Simulation Fluids Species – Mass Transfer – Multiphase Reply To: Species – Mass Transfer – Multiphase
There should be a mixture/species & properties for each phase. So, if you have N2 in a liquid phase (for example) with suitable properties and N2 in air you may well need to check your material definitions. Fluent may not check as the phase interactions don't always need to maintain balance in molecular weight etc: doesn't mean you shouldn't define correctly though!
