Ansys Learning Forum Forums Discuss Simulation Photonics Updating a Lumerical example Reply To: Updating a Lumerical example
kghaffari
Hi Sara,
Thank you for your detailed information. I noticed that in this example the "lock mesh" option is enabled for both CHARGE and FEEM solvers. To check the status of this option you can right click on the solver:
I think this is causing the issue. The lock mesh option will keep the mesh and settings that depend on it the same. This is particularly useful when running sweeps (which is done later in this example) to ensure that any changes are due to physical effects and not new generated mesh. However, it will also cause your design to not be updated. Please try disabling this option and try again. Let me know if the issue persists.
Best,
Khash
